I am using Circuit Builder with a custom template file for horizontal 3PH_H motor. My wire numbers end up in positions as shown:
Below is the placement of the WN01 markers in the template file. I also attach my template file and cb spreadsheet.
Thanks for your help.
Hi Jack.
I'm here also 🙂
There's no row in the excel sheet that references the ace_cb1_3PH_H_CC2.dwg file.
Is this the correct excel-sheet?
When using Circuit Builder, my wire numbers don't show up properly (I need them above the wire). They show in random places above/below wire or not at all:
Appreciate any help, Thanks!
Thank you and sorry for not replying. 3-day weekend here in Canada.
I think it is the correct excel file because when I rename it, Acad complains that it can't find it.
I changed both 3PH_H lines in the excel file: Even though I use non-reversing only. Saved and closed it.
Now what I get is that none of the tags get filled:
Help... Thanks.
Jack
I'm still not getting your files to work.
The motor for example, has M001 for the marker:
But, in the excel-sheet there's no repference to that. There the default MTR03 of course...
So should those two tags match..? If so, which one should I change - excel file or the template?
I am pretty sure I have never changed the motor tag in either file... At one time, I was getting most tags filled in.
I know I am missing something here but I don't know what it is.
Yes, those should match. How else will AutoCAD Electrical know where to put what symbol/circuit?
I suggest that you first set up this up correctly, and then see if this fixes your problems.
All the information you need is available in the product help:
There's also some videos for this available, like this one: https://www.autodesk.com/autodesk-university/class/AutoCAD-Electrical-Automation-Techniques-2019
