Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I have been trying to globally change the WD text style in my drawing and have tried via the Project/Utilities tab but it tries to process but does nothing and no errors. When I use the Enhanced Attribute Editor using double click on the attribute text and select the Text Option tab I see it is on WD and when I change it to another and then back to WD the attribute text does change. Is this a bug? It happens regardless of which way I process eg Current Drawing or Project.
Also I have limited Text Options in the Enhanced Attribute editor? Is this normal?
Is there a way to find out the current WD style?
Colin
