Change the font style for wire numbers only
Does anyone know of a way to change the font style for wire numbers and nothing else? I know of one way but I'm not sure it is correct. The only way I can think of is to edit the wire number block itself and change the text style in symbol builder, then save, overwrite and do a project wide swap block. My only issue with this method is I have always tried not modifying Autocads default components and saving over them.
I need a different font style for the wire numbers because I will be using mathematical symbols (the sine wave) and cannot just do a project wide font style change as all of the text on my existing components will no longer be positioned correctly.
I am doing the same for source and destination arrows but that's an easy one, I can just create a custom block for those.
Any ideas would be great! it's been so long since I have needed to modify text I have forgotten how alot of it works.
James
rhesusminus
You are absolutely right in your thought about workflow.
If you don't want to overwrite the existing ones, just put them in a separate folder and make sure that folder is "higher" in the list of schematic library folders in the project properties.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
