Change Plot Settings Project Wide
When I recieve drawing files from a customer to modify, the drawings are usually set up to their plotter.
I have to go through the project, one drawing at a time, & change the plot settings to my plotter in order to print the drawings.
I need a way to change ALL plot settings at once so that I don't have to do this one drawing at a time.
dougmcalexander
I have requested this on the idea station.  Please go vote for it at the link below.
http://forums.autodesk.com/t5/autocad-electrical-ideastation/set-plot-paremeters-at-project-level/id...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Yong.Jing
Autodesk Support
Autodesk Support
Could this setting match your requirement?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Dag_Henrik
The way I solve this is to first create a new project and adding all the drawings needed from the customer.
I then open one of the drawings in the project and start the command "pagesetup".
Here I create a new Page Setup and modify it as per my needs.
I find it helpful to use the "DWG To PDF" as my plotter. Then when I plot my drawings, I get them in one .pdf- file that I can save on the company server and later print to paper if needed.
I then start "Publish to PDF/DWF/DWFx" and select the drawings I want to plot.
Then in the "Publish"- screen, I select all the drawings that does not have the right page setup, select Import under the Page Setup row, browse to the drawing I changed the page setup for and Imports the setup.
sawalln
Community Visitor
Community Visitor
You my friend just saved me hours…next rounds on me 🫡
