AutoCAD Electrical Forum
Change PLC IO Address Layer
3 REPLIES 3
kswankZAHXZ
211 Views, 3 Replies
We want our device tags to have a heavier lineweight without making the PLC IO Address take that same heavier lineweight. Is there a way to assign the IO Address to a different layer?
3 REPLIES 3
Hello, @kswankZAHXZ ! Nice to see you in Autodesk Community! 😀
Would you mind to tell also what version (year) of AutoCAD Electrical do you use?
Alina Balkanskaia
I'm sorry, yes. I am using AutoCAD Electrical 2023.
jseefdrumr
in reply to: kswankZAHXZ
At first blush, I want to say that this can't be done, at least, not in the way you envision. But, before I can say that for certain, we need more info:
*are you using shx fonts, or true type fonts?
*are your drawings using ctb or stb?
*are these parametric PLCs?
*are you referring to the I/O address within the PLC symbol, or wire numbers that reflect the PLC address?
Even if we can't do this via layer assignments, we might be able to come up with a workaround, based on your answers to these questions.
Jim Seefeldt
Electrical Engineering Technician
