07:03 AM
- Mute
- Permalink
- Report
Hi All
I'm having a strange issue with catalog subcomponents. Nearly all of them are working perfectly, except for a couple where the main component is not picking up the subcomponents with the assembylist property matching their assembly codes. I can't see any difference in catalog data between the ones I have created that work and the couple that do not.
The ASSYCODE attribute in the symbol is being assigned the correct assemblycode, but when the Catalog Check is used it does not populate any subcomponents. One thing I have noticed is that when this happens the catalog description for the main component does not appear in the Catalog Check
