There is not a way provided to do this (good idea to log on the IdeaStation) but I did find some "under-the-hood" information on this.
We store all the favorite list, search history, and also the Column display/order information, etc in the following xml file, Autodesk.Electrical.SharedControl.Config.xml.
You can copy the xml file to other computers to share with other users.
Finding it is a little tricky. Look at :
C:\Users\{username}\AppData\Local\IsolatedStorage\bddq4gim.ust\rkxexbjr.qmd\Url.bit1plk2pr2oqaao31yhv31vjmnyzkds\AssemFiles\Autodesk.Electrical.SharedControl.Config.xml
The folder marked as red in the path is random generated, so you may need to search the file to get the path. And also you may see 2 folders if you have both AutoCAD Electrical and Inventor Catalog Browser Addin installed. And possibly more folders for other releases of AutoCAD Electrical.
What I did was add a favorite on both computers so I could see the updated date on the file it was changing. Then I copied the one from my computer to the other.
I would make backups of any files first before you start overwriting any, just in case. Especially since this isn't really a documented way to do this.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
