CAN'T CHANGE CATALOG ASSIGNMENT WIHT INSERT/EDIT COMPONENT (AEEDITCOMPONENT)
- Mute
- Permalink
- Report
I'm using Autocad Electrical 2017 SP1 on WP7 SP1 and in the past few days I have this error coming up on some projects: when I want to change the catalog part number already assigned to a component with the AEEDITCOMPONENT command it won't accept the value manually typed into the CATALOG box only a selection form the CATALOG database. The value typed in is replaced with the previous value when confirming OK in the edit component dialog window.
This is only happening for existing components in the drawing and not new ones added after opening the drawing. Also this error doesn't come up for every project, as far as I see it's either random or the criteria is beyond my comprehension.
It's been only a 2 weeks since I had to reinstall AE2017 and I don't yet feel like doing it again. I have AE2013 still installed on the PC, could this be the issue?
Any suggestion is welcomed.
