Cable Tag Name Default
abeachy
abeachy
Every time I insert a cable marker the Cable Tag always defaults to having a "/" at the beginning. It will be "/CBL-2202" which everything after the / is correct I just have to go in manually and delete the /. I assume there's a way to change this but I am having no luck finding the solution.
james.mcmillanNYR6A
