CABLE FROM\TO REPORT - CONDUCTORLIST FROM CATALOG
I would like to see the cable, conductor colors and/or numbers  BLK (1), BLK (2), BLK (3), etc. for example in the report.
Would it be possible to add the CONDUCTOR LIST from the CATALOG information to the CABLE FROM\TO REPORT? How?
Mike
No ideas? Not possible?
Part 2
How do people show connections to things that didn't have a symbol before? Make symbols or a easier way?
I am trying to figure out the easiest way to do this so we don't have to edit the TABLE every time we do something to it.
For example:
We use a Multi-conductor cable to go to a single PB enclosure, no terminals, wires are connected directly to an E-Stop.
The Multi-Conductors still need positive identification from CATALOG information. See first question above.
Then, how do we show and identify the FROM/TO information for a ground bar on one end and the panel on the other?
Add a ground lug to the enclosure symbol on the one end?
Create a Schematic Ground Bar Symbol and show the wiring?
How are others doing this so all information shows up automatically with the least amount of work after system is built?
Any input would be greatly appreciated,
Mike
rhesusminus
In the report generator, push "Change Report Format", and add the column CBLWC:
If you want the unused parts of the cable as well, press "User post", check the "Include entries for unused core/conductors" and press "OK".
Hopefully, this answers the question I believe you were asking.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
rhesusminus
The short answer is: If you want to display anything as "connected" in a report, you'll have to draw the connections. So yes, I'd use some symbols for the ground bar.
Trond Hasse Lie
Ctrl Alt El
TRLitsey
Hi there, here are two of my favorites.
Thank you
Please mark as a solution if this works for you, kudos are always welcome
Thanks guys for your help!
It is truly appreciated this forum has been my best tool for improvement.
Sorry it took me a little while to get back here, been stuck in a different groove.
THANK YOU!
Mike
