Cabel summary fields
davidp
davidp
Hi
I’m trying to create a cable summary report but I like to add field that are not available. Like Section and wire layer name.
I can get those fields in cable from/to report but I don’t want all the extra lines of each cable weir that comes with that report.
Is there any way to do this??
rhesusminus
If you use this User Post: http://forums.autodesk.com/t5/autocad-electrical-forum/cable-from-to-for-mounting/m-p/5276917#M37503
You can get a "cable summary"-report using the cable from/to report. Hence, you should get all the fields you need for your report.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
davidp
Hi this culd work. but I´am using ACE 2017 and It can´t find the right place to putt the files??
I find cabelcon.set, cabelcon.bat and cabelcon.SCR but not .lsp or .dcl
rhesusminus
Type
(findfile "cablecon.lsp")
At the command line to find the existing file. Files have been moved around a bit in AutoCAD, because of security (running unsigned code).
You can place the new version av cablecon.lsp/dcl somewhere else (like on a server), and make sure AcadE finds the file by placing a reference to the network location in AutoCAD's Options -> Files -> Support Files Search Path
Trond Hasse Lie
Ctrl Alt El
