AutoCAD Electrical Forum
C# .net sendCommand work some time and some time not.
0 REPLIES 0
Message 1 of 1
DINESHv.PAWAR
373 Views, 0 Replies
DINESHv.PAWAR
Hello Everyone,
In my current task I had wrote some code to Automate drawing (GA Drawing in AutoCAD electrical(2018) using C# .NET ).
The Code looks as attached .
As per code, The Main command is "GenerateSchematicDrawingforFETest". while calling this command.
The "TestGA" command is  run some time and some time it's not run.
I am not get why this happen.
I observe one thing the while using "TESTGA" the CPU usage is high up to 90-99% can this affect to run a command?
Please suggest any improvement or modification in code.
        [CommandMethod("GenerateSchematicDrawingforFE", CommandFlags.Modal | CommandFlags.Session)]
        public void GenerateSchematicDrawingforFE()
	// Some code to read drawingFilesList)
                    foreach (string drawingFile in drawingFilesList)
			//Check and Open Dwg File
                        string fileFullName = projectPath + drawingFile;
                        Document curDwg = null;
                        // DocumentLock lockDoc = curDwg.LockDocument();
                        if (drawingFile  != null )
                            curDwg = OpenDrawing(fileFullName);
                            if (curDwg != null)
                                acaddoc = Application.DocumentManager.MdiActiveDocument.GetAcadDocument() as AcadDocument;
				//This Command is run completely some time or some time not
                      		acaddoc.SendCommand("TestGA\r\n");
                                acaddoc.Close();
                                acaddoc = null;
       public Document OpenDrawing(string dwgFileName)
            //string strFileName = "C:\\campus.dwg";
            DocumentCollection acDocMgr = Application.DocumentManager;
            if (File.Exists(dwgFileName))
                Document dwgFile = acDocMgr.Open(dwgFileName, false);
                //dwgFile.IsActive = true;
                Application.DocumentManager.MdiActiveDocument = dwgFile;
                //dwgFile.CloseAndSave(dwgFile.Name);
                if (dwgFile.IsActive)
                    return dwgFile;
                else
                    return dwgFile;
            else
                acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + dwgFileName +
        " does not exist.");
                return null;
        [CommandMethod("TestGA")]
        public void TestGA()
            ReadExcelFile(); //Collect GA Data from excel
            BomGenerator generator = new BomGenerator();
            List<PanelComponant> panelForSheet = null;
            try
                var NamplateXmlDATA = ProjectData.requestDetails;
                foreach (var item in ProjectData.GACoOrdinateData)
                    if (item.Key.StartsWith(CurrentGASheetNumber))
                        //1. Get all excel sheet data of current GA drawing.
                        panelForSheet = generator.GetEachSheetDataInList(item.Key);
                        //panelForSheet = panelForSheet.OrderBy(m => Convert.ToInt32(m.Order.Trim())).ToList();
                        foreach (var componant in panelForSheet)
                            switch (componant.BlockType.ToUpper())
                                case "STATIC":
                                case "DYNAMIC":
                                case "KIT":
                                    LispInsertComponent(componant);
                                    break;
                                case "TEXT":
                                    CreateText(componant);
                                    break;
                        break;
            catch (System.Exception EX)
Thank you,
Dinesh Pawar
Hello Everyone,
                            if (curDwg != null)
                                acaddoc.Close();
                                acaddoc = null;
                    return dwgFile;
                else
                    return dwgFile;
            else
                return null;
            try
                                case "STATIC":
                                case "DYNAMIC":
                                case "KIT":
                                    break;
                                case "TEXT":
                                    break;
                        break;
Thank you,
Dinesh Pawar
Tags (1)
0 REPLIES 0
