Bulk Head Connection Diagram
dschneckloth
dschneckloth
Here is a fun one for you guys.  The attached (partial) picture shows a connection diagram for a 19-Pin Bulk head (CON-18) connector for assembly and field troubleshooting.  This project is complete in ACADE 2020. There are several of these bulkhead diagrams on one sheet (20-30).  These bulkhead diagrams reference the rest of the schematics in the project. Does anyone have any ideas on how to automate this connection diagram to the rest of the schematics.  The schematics themselves of course show were the wire connects are but are all over the schematic pages.  In this example, you will see 13105 13429 13431 S24V are all wire numbers.  1,2,3,4,5,6,7, are the pins of the bulk head connector.  Right now all of those mentioned attributes are just dumb, editable autocad blocks.  you have to manually edit each one of those for each attribute and each connector. We copy this bulkhead design from project to project and make changes and updates along the way.   With 20-30 of these connectors to a page, this is very time consuming to update.  If I could have some sort of ACADE attribute or commands for wire number 13105 and bulkhead pin 1 for example, if it is updated or changed in the schematics, then this bulkhead sheet would update as well. Same with the pins.  I know I am probably asking a lot, but any ideas would be greatly appreciated.
Replies (7)
rhesusminus
I can't really think of a way to do this without some custom programming. But it IS possible....
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
testsubject
I would start with trying to use Source/Destination codes and see where that goes....
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Two options:
Option 1.
create new symbol to suit your pictorial layout utilizing Source  / Destination features. this allows to have one source and unlimited destination. To be able to update the destination symbols, source symbol needs to be updated first ie. this option won't have bidirectional updates.
Option 2.
Create new symbol to suit your pictorial layout utilizing Terminal (TERMS) features. Tag strip can be used as wire number and terminal number can be used a pin number. when same tagstrip (wire number) and same terminal (pin number) are called up on multiple places (on same sheet or various sheet), ACADE automatically knows where this tag stip is used on. Whenever you update tagstrip (wire number), ACADE will prompt to update other peer tagstrips. This option provides  bidirectional update feature ie you can change wire number from any peer symbol.
I believe this should work but cant guarantee as I dont have enough time to test it.
Good luck!
rhesusminus
I'm not sure where my head was yesterday...
But you should be able to use a panel footprint that display this information via wire annotation. Did a quick test here:
My footprints are just a quick example of what they could look like.
Trond Hasse Lie
Ctrl Alt El
My understanding is this bulkhead connector pins and wires numbers are shown multiple times (20- 30 times) on same sheet or on various sheets. I think I have a solution, not perfect but works and saved time.
Either create a new symbol using parametric connector feature or just use (or modify to suit) HCN1J_ from the library.
I will use connector tag as wire number (in your case 13105), make it fixed. I will use one of the Description field to define connector pin eg. 1 for wire 13105 (VT conductor colour). I will copy this connector symbol and insert it multiple times (as required) on same sheet using  using ACADE "copy circuit", also can be done on multiple sheets (copy and paste but make sure you keep fixed original tag refs). I will select "Keep fixed components tags" when prompts after inserting the symbols.  Now all tags original and copied components have same fixed tag refs. Now I can update all tags (or pin numbers) by changing any one of the tag (in you case wire number) reference because ACADE automatically prompts to update the Related Components, see screenshots. Same way you can change pin numbers and conductor colour. BEFORE UPDATE.pngNEW WIRE.pngAFTER UPDATE.pngI have shown only one pin but same technique can be used for the rest of the pins.
dschneckloth
Trond
So what tags are you using in the 'circles' .  You are probably using PTAG for PL610 and PL710 i am assuming.  But what about the pins for 710 712 713 715.  What tags did you use there?  I am starting to like this solution so far.
rhesusminus
It look like this:
Use the Wire Annotation tool to populate the attributes:
Trond Hasse Lie
Ctrl Alt El
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
