Import/export to spreadsheet data - Multi Catalog information
tfe.evans
tfe.evans
Hello can you add multiple catalog information into a spread sheet for import?
Tom
JeffatPrimex
I'm not sure that is going to work unless you copy the whole row to include the block handle and drawing name my guess is the program would overwrite with the last supplied value. Backup everything before attempting.
Best regards,
Jeff
tfe.evans
Thanks you for the info.  I will do.  I also usually try things like this on a test environment.  I would not be the first time I broke something.  🙂
