First, insert a relay and the select catalogue lookup.
Find the relay you normally use and click on it to highlight the entry then click on the EDIT button.
Select the Main->subassembly checkbox and then put a code (I suggest the part number of the base) into the Assemblycode box.
You can have multiple parts in this box seperated by a SEMI colon (;) .
Close the edit box by clicking on OK.
Find the base part number and go into the edit screen for it. NOTE that if you can't find the base part number, try de-selecting the Symbol Name Filtering. (anything that is set to be a sub component is normally hidden from view
Select the Sub-Assembly box and put the same part number in to the Assemblylist box.
Exit out and reselect the relay. On the right hand side under the Web-View button there should be a piece of text saying MAIN->sub followed by some part part number. This indicates any sub components used for the item.
Any component that has a code in the Assemblycode box will automatically add any components that have the same code in the Assemblylist box. More than one component can call the same sub component which makes it easier. For example, you could have several different relays with different coil voltages, all using the same base, securing clip and label.
An easy way to set this up is to have CODE1 in the Assembly code box of the relay and CODE1 in the Assemblylist boxes of the base, Securing clip and label.
Another way is to have CODE1; CODE2; CODE3 in the Assemblycode box and have CODE1 in the base Assemblylist, CODE2 in the Securing clip Assemblylist box and CODE3 in the Labels Assemblylist box.
This will work on all the components so I would reccomend setting this up on your commonly used components as you come across them. It only has to be done once and will not need to be done again unless you upgrade or have to change part numbers.
Regards Brad
Brad Coleman, Electrical Draftsman
