Block cannot be exploded
I set the this setting for the block but don't see a way out of it.  I'd like to explode a protected block.
rkmcswain
How is it "protected"? Is this a normal AutoCAD block or something specific to Electrical?
Have you done this?
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Block-ca...
I thought what you had presented was a correct solution for me.  I ended up trying it this am, Tuesday and things are not happening as I would have expected.  I have a block that was not properly marked on creation, It's locked from being explodable.  When I follow what you were presenting, things are vastly different or non apparent after I call up the block editor.  I am not seeing a properties palett tab on the block authoring paletts pop-up.  I see constraints, parameters, parameter set, and actions.  Might I be looking in the wrong spot?
Ok , I'm good now.  I had to right click a few times to get me to the correct pallet.
-M
