AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Bill of Material Sub Assembly Quantity Count
6 REPLIES 6
1567 Views, 6 Replies
I need some help on getting proper quantity count when I generate BOM. For instance I have a disconnect switch and it has 2 sub assemblies parts that were  added to it (I added them under multiple catalog option). When I generate the BOM I get the CB as quantity 1 , but the 2 other parts that were added the quantity doesnt show up. I have to check SUB category on BOM to see it show up at *1. How do I correct this problem ,so it counts my sub assemblies parts for a quantity, so I dont have to manually go in and edit the BOM.
Thanks a bunch!!!
6 REPLIES 6
sonny3g
Look in your report for a button "User Post" and see if there is a sub-quantity add function in there.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
in reply to: sonny3g
thanks it works !
HI ,
could you please tell me how to resolve the sun assembly count issue.
i am using 2018 ACE software.
sonny3g
Sorry, I haven't used AutoCAD Electrical since 2014.
Scott G. Sawdy
jalger
same as before,
Run the report on the Project (or Drawing[s])
once you have the report window up select "User Post"
then select "QTY x SubQTY ---> QTY Blanks out SubQTY" (its the 2nd user post option)
that's it.
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
daniel.poeGG2QF
I have been trying to fix my Bill of Materials for almost a week now. I could not get the QTY and SUB to display the proper quantity of any item. Thanks for sharing the "User Post" setting!!!!
