Best way to determine zoom factor for smart PDFs
Has anyone had any experience with the smart PDF zoom factor? I know that the zoom factor is calculated as a percentage of the object's size but I am finding it difficult to determine the best factor to use. Sometimes it will zoom in much too close and sometimes not nearly enough. Does anyone have any advice on how to best determine the zoom factor? Any advice is appreciated. Thanks,
Brian
Yong.Jing
Autodesk Support
Autodesk Support
Could you use pdf plotter to preview printing windows. Here it could give you some scale. Is this fine to you?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Thank you for the reply but what I am referring to is the zoom factor scale when creating a smart PDF. Is there a there a way to test this from the pdf plotter preview?
jalger
Zoom Scale is determined by the PDF viewer and your mouse settings.
The zoom increments are generally hard coded into the viewers.
The mouse Sensitivity can be set in windows with the mouse select in control panel.
(how quickly you scroll through the increments)
You can change the initial view to "Fit Page" but again that is in the PDF viewer.
(in Adobe's* case its under preferences > Page Display > Zoom)
*for Adobe acrobat
You can change the page size to alter zoom scales. (A [8.5 x 11], B [11 x 17], C [17 x 22], D [ 22 x 34],E [33 x 44]) (or the Metric sizes A4 - A0)
The only other thing you can do to make the image sharper is to Increase the DPI, and make sure you center the plot with a preset print scale.
I hope this helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
rhesusminus
OP is talking about the zooming that automatically happens when clicking "hyperlink" in an intelligent PDF created by AcadE.
If you click the xref for a child contact, it will go to the sheet where the the child contact is inserted, within the PDF, and zoom in on that component.
Unfortunately I don't have any ideas on what the ideal zoom factor would be. I'm quite pleased with the default value of 50.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Brailyn
I think I found the answer to what you are wondering... here:
Note: Before publishing, update component and signal arrow cross-referencing.
The Zoom factor controls how close the PDF file is zoomed in when you click a hyperlink and are taken to the corresponding object. The zoom factor is calculated as a percentage of the object's size. A Zoom factor value of 50 means the object is shown at half its PDF object size. A zoom factor value of 100 means the object fills the PDF screen. Enter an integer from 1 through 100.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
