How do I get rid of this Text Style?
I need to get rid of it to pass customers standards check.
J.
Solved by rhesusminus. Go to Solution.
I tried all that even the dxf trick. I could get rid of the AW_TAG style and even then when I go to insert it I get the style back. ACE must be adding it on the fly. I just tried a really old cimlogic wd block and get the same style added and of course standards check error.
This is like a VIRUS !!
Attached is a fixed copy of your block. However.. It would be painful to do this for an entire symbol library.
Any way you can just rename the text style?
Thanks for looking into this and that file. I tried it but get the same results with that file. I tried it on the demo project and it did not create the AW_TAG test style. So then I tried creating a new project and setting it up manually with all the customer setting then used your block and I still get that text style.
Perhaps it would help if Anyone could shed some light on When Why and How this Text Style came to be. I was able to delete the Standard style which leads me to believe this AW_TAG style was the Standard style at one time. There must be a similar block stuck in the provided template drawings database that assumes the Standard style is AW_TAG for that block.
Is there any .dwg/.dwt analyzer tools that may help to troubleshoot this?
J.
Trond You're Awesome!
How on earth would you or anyone that's not an ACE programmer even know this?
Thanks!
Now I just have to figure out a way to fix this MESS.
So... With the help of some fellow expert elites, I was able to make some code that did this automatically.
Attached, you'll find the NFPA and NFPA/1- symbols that had the AW_TAG text style in them, now without the AW_TAG text style.
It's not like I have anything better to do at night
I guess you need to do the same with some of your drawings also, but I'd like to test with some of your drawings before releasing the program, making you able to this yourself.
Wow That's what they call going the extra mile!
I haven't created any drawings yet that have this particular text style in them so I'm good there.
I purchased a batch utility to fix the blocks that had that style. As we can see there weren't as many as previously thought.
"WD" was one of the styles that was acceptable so I just converted them all to dxf format then ran a script I found on the web to search for "AW_TAG" and replace it with "WD" then converted them all back to dwg format. I should have waited!
I'm sure others could use your program especially the AutoCAD Electrical team so they can clean up this Mess.
Thanks Again,
Jeff
