Is it possible to have the automatic reports insert a table on the currently opened drawing?
Hi @MatthewDBell,
I'm just checking in to see if you need more help with this. Did the suggestion that @rhesusminus provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris,
I need help with this. Every time I run the command, it creates a new DWG
