Automatic Reports
Automatic Reports
MatthewDBell
Automatic Reports
MatthewDBell
Is it possible to have the automatic reports insert a table on the currently opened drawing?
rhesusminus
Not unless it already have a table that should be updated.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
ChrisPreece
Hi @MatthewDBell,
I'm just checking in to see if you need more help with this. Did the suggestion that @rhesusminus provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
zsobieXK43E
Chris,
I need help with this.  Every time I run the command, it creates a new DWG
