I am new to this forum and this is my first question.
I´m learning how to program with Autolisp and I have a problem running an Autocad Command in a Autolisp program.
When I type WD_P2P_CONNECTOR_DLG_WNUM_CHG command in ACE (Autocad Electrical) a window popup show up. Showing that the ACE command is running fine. But instead, I try to run the same command in autolisp:
(command "WD_P2P_CONNECTOR_DLG_WNUM_CHG")
And the following message show up:
Unknown command "WD_P2P_CONNECTOR_DLG_WNUM_CHG". Press F1 for help.
1) What am I doing wrong??
2) There is a way to know the argument that WD_P2P_CONNECTOR_DLG_WNUM_CHG command accepts to use it in autolisp??
Thanks in advance, sorry for my english!
Solved by james.mcmillanNYR6A. Go to Solution.
have a look in the API help here
I searched for 'connector', and think you should try
Thank you so much!!. I couldn´t use c:ace_cb_parametric_connector but instead found c:ace_ins_parametric_connector that work perfectly.
