AutoCAD Electrical Schematic Specification Report
kalumb-boom
kalumb-boom
Hello everyone. I’ve run into an issue with schematic bill of materials (BOM) reports. The default report layout leaves much to be desired, as each element occupies a separate position within a single line. I managed to configure the report (using a custom function) so that elements are listed with commas and multiple items fit into a single column. However, this approach fails when there are too many elements. Is there a way to format the list like "KL1...KL22, KL26, KL28"? Also, I need each new entry to create a new row rather than expanding the existing one. Perhaps someone has already solved this problem and can point me to a relevant discussion?
rhesusminus
You'll have to program a user post to "massage" the report data and return the desired result.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
kalumb-boom
Thanks for the reply. As I understand it, this is implemented by configuring the Bill of Materials (BOM), and there are no off-the-shelf solutions for this. It’s a shame that such a simple function requires delving into programming within the software itself.
rhesusminus
Well, according to some users, this is the STRENGTH of the program. The flexibility to be able to program custom solutions. (Well... Most other programs do that also)
Luckily for you, there are cheaper programs out there that will do this out of the box. This is Eplan Electric P8 Basic:
Trond Hasse Lie
Ctrl Alt El
