AutoCAD Electrical Interface Problem
bang_duy_nguyen
bang_duy_nguyen
We have installed AutoCAD Electrical 2023 , and the desktop shortcut shows as "AutoCAD Electrical 2023". When I open the software, the startup screen shows AutoCAD Electrical 2023, but once inside the program, the interface is not the Electrical interface—it appears to be the Mechanical interface. I don’t know why this is happening. I’ve checked the installation folder and confirmed that the Electrical folder is present. Please guide me.
Pls see in video attached
arshdeepsingh404
Hello @bang_duy_nguyen
There is no video attached with your post, Can you update the post with a video or a screenshot of what you are seeing please.
Also, can you check if the workspace is set to AutoCAD Electrical (ACADE & 2D Drafting & Annotation)?
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
bang_duy_nguyen
All symbol is "?" after i loaded the profile ACADE
bang_duy_nguyen
see more pictures
bang_duy_nguyen
Video as below
arshdeepsingh404
Is this the default installation or did you change anything?
The Electrical (Acade.cuix) customization file is automatically installed with AutoCAD Electrical, so you don't need to manually load it like in the video.
Missing icons could be related to File Support Paths or a bad cuix file. Have you made any modifications to the environment file?
Here is a related forum post about missing icons: https://forums.autodesk.com/t5/autocad-electrical-forum/icon-symbols-are-missing/td-p/7659432
Try resetting AutoCAD Electrical Settings
If that doesn't help, Do a clean uninstall and install the program again.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall.ht...
Arshdeep Singh
bang_duy_nguyen
After reset to default , it worked . Thanks for your support
