AutoCAD Electrical Forum
Autocad Electrical Fatal error: Unhandled e0434352h Exception at D908428Ch
4 REPLIES 4
sdurak9CT7Y
429 Views, 4 Replies
How can i fix this error ? I cannot use Autocad Electrical.
4 REPLIES 4
rhesusminus
in reply to: sdurak9CT7Y
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/FATAL-...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
sdurak9CT7Y
in reply to: rhesusminus
I guess, It is not my problem solution because Exception at fd1ba06dh different problem. It was working until I turned it off and when this morning i turned it on i saw this error
rhesusminus
Well, the article is titled "Fatal Error: Unhandled e0434352h Exception at... " for a reason. The address the last numbers, will be different from machine to machine.
Anyway. The information you've provided is equal to saying "my car won't start" when you call for help. It won't give us the information needed to help you.
So, it worked yesterday. Do a reboot help? Do you have all updates installed for AutoCAD Electrical (Use the Autodesk desktop App to check)? Did Windows update anything during the last reboot that might have caused this?
Trond Hasse Lie
Ctrl Alt El
sdurak9CT7Y
Yes, windows did an update on the last startup and then Autocad started giving fatal error.
Now, I tried Reset Settings to Default - AutoCAD Electrical and finally it worked
Thank you for your response and help.
