Autocad Electrical 2014 does not start: stuck in loading wd_mdb.arx
Hi there,
We are using AutoCAD Electrical 2014 SP1 on Win7 SP1 clients.
We are currently facing issues, which did not happen in the past.
AutoCAD Electrical 2014 does not start: it gets stuck in loading wd_mdb.arx
We tried uninstall and reinstall, but still issue is there.
We tried to remove wd_mdb.arx file, but it then get stuck in loading wd_dcenter.arx, wd_utils.arx
If we remove these files from the install location, AutoCAD Electrical starts and we can load (APPLOAD) after these files (wd_mdb.arx, wd_dcenter.arx, wd_utils.arx) manually
Can anyone help?
Thanks a lot!
Hi there,
We found how to get it solved and hopefully this will help others.
In the file Acade.rx, we changed the order of application to be loaded when launching AutoCAD Electrical.
It was:
acsiui.arx
wd_mdb.arx
wd_dlg.arx
wd_dcenter.arx
wd_utils.arx
wd_dwg.arx
ace_mb.arx
?AceShellExtension.arx
..\AcePmClientApp.arx
..\AcePmDefun.arx
AceMDIGblManager.arx
?AceAddIn.arx
AcePageMan.arx
?AceEtransmit.arx
AceJumper.arx
AceTerminalStripEditor.arx
AceDialogs.arx
AceAudit.arx
AceAIP.arx
AceWireType.arx
AceCompUI.arx
AceDataExchange.arx
AceSymBuilder.arx
AceCircuitBuilder.arx
AceMigrationUtil.dll
AceDBEditor.dll
AceCatalog.WPF.Client.dll
AceProjectCatalog.arx
AceMarkingMenus.arx
We changed it to:
acsiui.arx
..\AcePmDefun.arx
?AceAddIn.arx
AcePageMan.arx
?AceEtransmit.arx
AceJumper.arx
AceDialogs.arx
AceAudit.arx
AceAIP.arx
AceWireType.arx
AceCompUI.arx
AceDataExchange.arx
AceSymBuilder.arx
wd_mdb.arx
wd_dlg.arx
wd_dcenter.arx
wd_utils.arx
wd_dwg.arx
ace_mb.arx
AceDBEditor.dll
AceMarkingMenus.arx
That solved our issue.
