I create 2 symbols. Symbol1 and Symbol2 both have 9 Circled Terminals with Left/right/up/down connectors.
I will run a wire from each symbols Terminla 1-9 and I connect no problem using X.
The problem I have is when I try to use the Wire Tagging Drawing-wide. It only tags 2 of the wires.
As you can see the image below only the Green and Brown wire types get numbered.
If I try to edit any of the other wires it only changes the brown wire.
Thanks for replying. Yes, I did use the symbol builder and they are just like you said and from what I see each TERM has proper naming.
I've opened other symbols that came with ACADE2017,2016,2015 and I don't see anything different other than my pattern is a CIRCLE.
I created a connector with 9 terminals and positioned them vertically and it works.
Would Circle pattern cause it to fail?
I am still quite new to ACADE so this is only a guess but, what happens if you try to add wire numbers without the wires connected to the block on the left? Did you create the block on the left as well? If so, perhaps there is a problem with these X?TERM attributes.
Yes I did create it, but then I thought the same that it might be the problem so I used ACADE Terminals and still same result
thanks
What the distance between the connection points (X?TERMXX) ?
Is it less that the wire trap distance?
If you use the AESHOWWIRESEQ command... Does it say that they are all connected`?
I found a solution so far its been working.
When creating my symbol I was giving it a name of number 2000281_001.
Once I renamed them and put a letter first A_2000281_001 the symbol worked like it should.
