I know there is a way... just can't remember...
How does one reference a drawing file name in an attribute...???
example: an attribute in a title block that shows drawing file name....
help me... plzzzzzzzzzzzzzzzzzz.....
Solved by jalger. Go to Solution.
this is for plain autocad
go to properties on the attribute in block editor etc
change the attribute property multiline to "yes"
click on the button on the right hand side to value in the properties menu
a menu will appear tittled text formatting
first item is insert Field
Select that button and the various fields will appear
or you could use Titleblock mapping...
and assign an attribute to the Drawings Filename value.
Make sure you go to the Drawing values section, the File name has 3 options. (with path and extension, with extenion, and just the name.)
I hope this helps,
James
Thanks.
Hey is there any way to make attributes match the file name and for attribute not to change when it's xfre into another file or the text you apply the code.
