Additional backtick (`) in WDT file appear in Title Block Setup dialog
yoonghm
yoonghm
I have a project LAB2 which uses a project-specific WDT file: LAB2.wdt.  The file has the following entries
BLOCK = TITLE_BLOCKS_A3
SH`# = SHEET
SHTS = SHEETMAX
TITLE`#2 = DD1
DATE = PLOTDATEYYYYMMDD
TITLE`#1 = LINE1
DRAWNBY = LINE3
CHKDBY = LINE8
I guess that the backtick in the file was created by ACADE to escape the hex (#).  However, the Title Block Setup dialog show TITLE#1 and TITLE`#1.
However, choosing TITLE#1 and TITLE`#1 via this dialog box still save the value as TITLE`#1 inside the WDT file.
Perhaps TITLE`#1 etc. should be removed from the dialog box to avoid confusion.
Accepted solutions (3)
rhesusminus
The apostrophe should be placed before the attribute name:
https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201...
Like this: `TITLE#1
Will AcadE list TITLE#1 once then?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
yoonghm
Hi @rhesusminus , thank you for your reply.  The solution does not work.
If I use `TITLE#1, TITLE#1 and `TITLE#1 will appear in the Title Block Setup dialog.  It should be a bug in ACADE 2022 (or earlier as I could not try this function in older version).
rhesusminus
Yup. It might just as well be a new "feature" in AcadE 2022. If it works in 2021 and previous...
Trond Hasse Lie
Ctrl Alt El
