Multiple Insert Schematic multiple level terminals
Thomasbatson
Thomasbatson
I am using ACADE 2021, when I use the multiple insert function for multi-level terminals, the levels do not show up properly.  After the insert the 1492-JD3 terminal shows as single level so I have to go back through all of them individually, go to catalog lookup (fortunately since catalog is assigned it goes right to it), reselect the same terminal catalog number and then it updates.  Is there some fix to get this to work as it should or is anyone else noticing this as well?  I have 2 images to shows Edit Terminal after multiple insert and after reselecting the same catalog number.
Thank you for the help.
rhesusminus
I'm not able to replicate this.
However, I'm using 2022 now.
Can you create a video showing you process? Use the free screen capture software from Autodesk to create and share it with us. https://screencast.autodesk.com
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
