AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Adding Wire
2 REPLIES 2
343 Views, 2 Replies
Adding Wire
when i insert a wire it will not let me insert a wire from wire to wire. It just changes the path of the wire.
2 REPLIES 2
JeffatPrimex
You should look into using windows snipping tool capture screen shots. Looking at your drawing I assume that triangle of lines is not what you wanted but ACE drew them for you. My guess is you just need to erase the lines and wire numbers between devices and then use the add rung tool.
Best regards,
Jeff
jseefdrumr
in reply to: JeffatPrimex
It would be helpful to know which wires you were trying to connect also. It almost looks like you were trying to add a twisted pair symbol that went wonky. Hard to tell what was going on before.
And yes, the snipping tool is our friend, lol. It makes posting screenshots to the forums pretty easy.
Jim Seefeldt
Electrical Engineering Technician
