Adding Wire Connection Attribute to From/To report
I have just started using AutoCAD Electrical (version 2015) so apologies if the question is an easy one!
I've wired up a schematic and want to add the wire connection description attribute (i.e. X?TERMDESC??) to the From/To report. I've seen some documentation on creating .wad files and tried this method but did not succeed.
Can anyone give me guidance on how to achieve this? Any advice would be greatly appreciated.
Found the answer!
It is PD1 and PD2 when you go into Change Report Format.
