Adding parts to AutoCAD Electrical Catalog
muckmailer
muckmailer
I have a BOM in excel which has parts that are not included in the AutoCAD Electrical Catalog.
I there a quick way to add information to the AutoCAD Electrical Cataogue using a cut/paste
method.
Hopefully a method that would allow me to put many parts in the catalog at one time using cut/paste.
Thank you,
dougmcalexander
If you are using release 2015 or newer the Catalog Browser functions in a similar fashion to a spreadsheet.  You can add new records by using familiar right-click, copy, paste, as you would with a spreadsheet.  You will need to select the appropriate table within the Catalog Browser and click the pencil button to enable Edit mode.  You will need to arrange the columns in you spreadsheet to correspond to the order of the fields in the Catalog Browser.  You cannot, and should not, re-order the fields in the Catalog Browser.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
rhesusminus
I have done a quick screencast for this: https://knowledge.autodesk.com/community/screencast/d31c5464-6665-405b-b955-1dcf34dec445
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
