Adding new PLC modules: PLC database and Default database
rwcanary99
rwcanary99
I successfully added a 5069 module to the PLC Database.
3 questions:
How do I get it to break if it runs out of ladder lines?
Can I edit the component and tell it to break?
Do I have to ALSO add it to the default DB, because its not showing up in there?
PeytonHarriss
Question 1:
I'll assume you mean create a break on your PLC after its been drafted.  Using the split PLC command would be useful.
https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201...
Question 2:
question 3:
Can you elaborate?
rwcanary99
Sorry Peyton, I thought I had replied to this already.
thanks for 1 and 2
#3:
I inserted the new PLC module into the drawing.
I even created the footprint for the panel layout.
I could not get the footprint lookup to act right, unless I added the same module info to the ACE_DEFAULT.mdb.
is this normal, or did I create the new module incorrectly?
PeytonHarriss
You may be looking for this.
rwcanary99
I’m looking for AB’s mdb.
so I don’t have to add each model.
I would rather have to add old slck500, than add the new ones.  Because nobody builds out SLCK anymore.
PeytonHarriss
https://forums.autodesk.com/t5/autocad-electrical-forum/out-dated-plc-database/m-p/10723769#M74031
its the same answer for the Footprints as it is for the parametric PLCs and the schematic PLC database.  I wish I had a better answer but I do not.
I would say lets start a github to make an updated database, but I wouldn't be suprised if folks would fight over the right way to configure the footprints, schematic symbols, and PLC database.
