Activate project
Activate project
Activate project
HI everyone,
I am new to using AutoCad. My problem is that multiple projects are in the project manager list and when i update my title block i have to dig around the list to find out which project my schematic belongs to.
Is there a way i can activate the project of the tab that is currently open?
Thank you for the replies.
TRLitsey
Hi there,
I could suggest that you right click on the tab.  Select OPEN FILE LOCATION and hopefully each project is in it's own folder.  Then click on the [project].wdp file to set it as active.
Good luck
Please mark as a solution if this works for you, kudos are always welcome
Thank you for the reply.
That is a neat shortcut that i could come in handy.
However, When i have multiple files of multiple projects open, by opening the project file, it does not activate it for me.
