3 Phase Incoming Power Labels
Message 1 of 8
Is it possible to use the %S%N format for my initial 3 phase power wires?
How do I get the wire numbers to appear at the top of the wire rather than in the middle of the wire?
Replies (7)
Message 2 of 8
TRLitsey
Hi there,
This may be the tool you are looking for.  You can also add wire number marks anywhere on the wire.
For 3 phase I like to use this tool to set the wire numbers like sheet 3 line one as,  0301-L1, 0301-L2, 0301-L3 etc
Please mark as a solution if this works for you, kudos are always welcome
Message 3 of 8
I guess I need to clarify, when I inserted the wire numbers they were automatically inserted to the middle of the wire.  I'd prefer for it to insert at the top where as you show in your pictures without any additional intervention.
Message 4 of 8
TRLitsey
Ok, now I see what you are asking.
In the active project, in the Project Manager, right click on the Project Title, from the fly out menu select Properties ...
Message 5 of 8
Does this apply to all wiring?  Seems fine for wires within the ladder but not the originating wires.
Message 6 of 8
TRLitsey
Well, this may not work for you but this is how one of my schematics started out.  Not the best example it's just a "for instance".
Good luck
Message 7 of 8
dougmcalexander
The settings you choose in the Drawing Properties determines the location of the wire number. The default is middle. You can always use the Move Wire Number tool to select a different place on the wire where you wish to move the wire number to. The software will remember this even if you run wire numbering again.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Message 8 of 8
rhesusminus
These are the Project Properties. Check that the DRAWING properties also is set have the wire numbers above wire.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
