Announcements
ACADE2024 - Hyperlinks in PDF still not working when using SHEET attribute in cross reference
nicolas-v
nicolas-v
After looking at this topic seems this bug is still here in Acade 2024.
https://forums.autodesk.com/t5/autocad-electrical-forum/acade2020-hyperlinks-in-pdf-not-working/m-p/...
In blue, I used XREF attribute in a custom standalone cross-reference symbol and hyperlink is generated.
In red, I used SHEET attribute in the same symbol and hyperlink is not generated.
In default hexagon symbol, no hyperlink is generated...
Anyone can confirm, please?
I needed to have only sheet number for a specific page, so I guess I will need to modify sheet properties and change cross reference format.
Using AutoCAD Electrical 2024
jaya_priya_ramasamy
Hi @nicolas-v
I am not able to reproduce the issue with hexagonal signal arrows.
Is it possible to give a small set of drawings with the issue mentioned for us to test?
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
nicolas-v
Hi @jaya_priya_ramasamy
Thanks for having a look.
I attach a zip with my test project and the generated pdf.
jaya_priya_ramasamy
Hi @nicolas-v ,
If only there are stand-alone cross-references, then the PDF hyperlink is not working. I will log this as defect.
As a workaround, you add a wire in sheet1 and insert Source arrow and choose hexagonal arrow. In sheet2, add a wire and insert matching destination arrow and choose hexagonal arrow.
Then generate PDF and check. All the standalone cross references will work. Then you can delete the newly added signal source/destination and regenerate the PDF and check again. It will continue working.
Please try this and let me know whether this workaround works for you.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
nicolas-v
Thanks for this workaround, but it didn't work.
In the hexagonal arrow, there is SHEET and XREF attribute.
When inserting default hexagonal block, XREF attribute doesn't follow Drawing properties XREF settings which is p%S-%N between drawings.
If I update Stand alone XREF (AEUPDATESAXREF) and Pick which hexagonal xref I want to update, then format of XREF attribute is updated according to drawing properties.
Then, in that case, generating Pdf also generate hyperlink for the XREF attribute only.
So I guess hyperlink cannot be generated for an xref that has only SHEET attribute.
Since I need to use this custom stand alone xref block on specific drawing only , I will change the xref format for drawing as a work around.
jaya_priya_ramasamy
Hi @nicolas-v ,
Thank you for the update.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
