ACADE Find and Replace Script/VBA Code
We often have it where a customer requests that we change the naming of a project, robots, equipment, etc. Sometimes this naming varies throughout mtext, attributes, etc. I'm looking for the easiest way to automatically run through all of the drawings in a project and replace any instances of the text that I'm searching for. Can anyone shed some light on the easiest way to do this? From what I've seen as far as built-in ACADE features it's only for component attribute data. I'm looking for VBA Code/Script/LISP type function. Not the excel import/export or anything else. Any help is greatly appreciated! Basically, a MFIND script command that works.
rhesusminus
Have you had a look at this?
https://www.cadstudio.cz/en/apps/srxtext/
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Very powerful tool for replacing text/attributes  in drawings or folders of drawings
http://www.lee-mac.com/bfind.html
dshood
Try this lisp routine that we use all the time.
We write it into a script file and run it though the script utility in AutoCad Electrical.
