ACADE 2024 - Paper Space
ryourgal
ryourgal
Where I work, we are considering switching to ACADE, and not that I'm a big paper space fan, but I've read that ACADE doesn't play well in the paper space world is this correct?
Robert Yourgal
OP21
Not at all...
I've been using a PSpace for titleblocks and viewports to display schematics and mechanical layouts.  As long as you set up your titleblocks correctly, use 1 dwg per page in the project, signal references and titleblock information will update without issues.  Mechanical layouts are always drawn 1:1 and you avoid a scale up or down percentage to get the the mechanical layouts to fit the page size, this is easier to do in PSpace and use scaled viewports.
IMO, PSpace allow more flexibility to present your dwgs...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
Cole64
It is just designed different. If you use it as it is designed then there are no issues. Like Omar says "use 1 dwg per page in the project, signal references and titleblock information will update without issues" don't try to treat it like ACAD which is designed for mulitple paper space sheets off the same drawing.
