ACad Electrical Balloon Settings
I know I can change balloon settings in panel config, but that only changes the settings for the current drawing. How can I change the settings permanently?
jseefdrumr
Not sure about your version, but I use ACADE 2015 and I set my balloon config in my template. I don't have to set them each time I start a panel drawing. I can't imagine why that functionality would be any different in another version, so this ought to work for you too.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Have you tried changing  the setting in the  template you use...
TRLitsey
Hi there,
The above posts are correct but if you have to ask that question I would add a suggestion or two.
Whichever drawing type you are using for your base drawing, either .dwg or a .dwt file try this. Open your base by double clicking on it.  Either file type will open normally.  Base drawing probably only has your title block in it and the basic CAD elements.   Go through your process for setting up your balloon preferences, but don’t stop there.  Go wild.  You can load all the line types you use, all the layers, snap preferences, grid preferences, load wire types, dimension style settings.  Just about every drawing variable can be loaded up and defined.  When all the bells and whistles are load do a “save as” to save over the .dwg or .dwt file with the loaded file, be sure to use the ‘save as’ and double check the file type being saved, .dwg or .dwt.
Next time you start a new drawing with this as a template, everything is loaded and tweaked, ready to rock and roll. If you have so many files on your system that space is an issue, just remember to clean the drawing.  That is to say, when you are finished with the drawing and are ready to publish, run the Purge All tool.  That will strip out everything not actually used in the drawing.
Standard file templates:
Templete file when creating from within ACE:
Please mark this as solution if it works for you, kudos are always welcome
Good Luck
Please mark as a solution if this works for you, kudos are always welcome
Thanks..I don't know why I didn't think of that...Brain fart.
