Acad electrical 2017.1.2 update problems
Wheelie22
Wheelie22
This update does not install. using the Autodesk Desktop App.
It starts the install but the bar stops here :
And the App removes the 2017.1.2 line, but after a restart (PC) it is there again.
How can i see if it's realy installed ?
This is the Acad info :
rhesusminus
It's not installed.
You should be on version N.402.0.0 is you had 2017.1.2.
Probably, someting went wrong during the installation.
Download the update manually from https://manage.autodesk.com/cep and try to apply it manually instead.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Wheelie22
Thanks, this worked, the acad admin downloaded the file :
I did a repair and the install bar went the full 100% Smiley Happy
And after a restart the ADA was empty.
