2020 AUTOCAD ELECTRICAL PROJECT MANAGER
Message 1 of 8
I just got upgraded to 2020 acad electrical.  The issue i am having is that the projects are not staying in my list of projects after i restart the software.  I assumed it was an issue with the "LastProj.fil".  i tried that solution but that is not working.  I started to look at the my drawings again and noticed that the file "LastProj.fil" is now appearing in the folder where my files are.
and now under my c:  C:\Users\******\AppData\Roaming\Autodesk\AutoCAD Electrical 2020\R23.1\enu\Support\User the file "LastProj.fil" stays blank
Thoughts?
Replies (7)
Message 2 of 8
rhesusminus
Is your AcadE data shared on a server?
https://knowledge.autodesk.com/support/autocad-electrical/troubleshooting/caas/sfdcarticles/sfdcarti...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
yes my folders are on a shared network at work. The thing is  i am the only one with this issue
Message 4 of 8
rhesusminus
Did you try the solution in that article?
You should also search for and delete all instances of lastproj.fil
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
yes, i deleted the file and all instances of the lastproj.fil......
i just noticed the projects come back after i select a drawing to open.  but the lastproj.fil on my c: is not up to date, only where my projects are is updated.
Message 6 of 8
rhesusminus
But, have you tried to add the extra path to the support file search paths, as suggested in the article?
Trond Hasse Lie
Ctrl Alt El
Message 7 of 8
i am not sure on changing the paths
this is what i have, we usually never touch this stuff
Message 8 of 8
rhesusminus
So, you don't have the wd.env file etc. on the server... Just projects? Then that fix won't apply.
Trond Hasse Lie
Ctrl Alt El
