- Mute
- Permalink
- Report
Is there a way to have 2 different wires with different wire numbers land on the same terminal without having the wire numbers change to one or the other?
Basiaclly, I have an Analog - wire, and the shield from the twisted pair, that is to be connected to the - terminal of a current transducer (per the manufacturer's wiring diagram!) But when I go to make the signal wire a particualr number, and the shield a shield. AutoCAD throws a fit and labels both wires as Shield (because yeah, 1 terminal, all wires SHOULD be the same number)
Link copied
