Would anyone please share some idea of what i did wrong in my symbol?
I created a new symbol (on the left) and insert the symbol as 2-pole circuit breaker with description "Pump Isolator", Tag "04Q2" & rating "32A" the 2nd symbol repeated the same information as the first symbol, which i don't want to be repeat information.
I inserted IEC symbol on the right and gave similar information, the 2nd symbol does not repeat the information as the first symbol.
Solved by KHOPE677VG6PJ. Go to Solution.
Solved by JeffatPrimex. Go to Solution.
I don't think that will ever be fixed so you might want to set the rating attribute in the secondary blocks to invisible true.
Best regards,
Jeff
I am new to ACE. Please advice method to set the rating attribute in the secondary blocks to invisible true.
I use JIC symbols so your file names may differ.
Steps
1. Identify the name of the secondary symbol example hds21
2. locate and open hds21.dwg file. You can find the path in project properties project settings expand schematic libraries.
3. Select the Rating2 attribute right click and select properties.
4. Change Invisible to Yes.
5. Close file and save.
6. Run component swap update block if there are existing secondary symbols in the drawing.
Best regards,
Jeff
