1734-TOP catalog block
Message 1 of 11
I am trying to find a block for 1734-TOP. I'm wiring a 1734-IB8 into a 1734-TOP. I am looking for a legitimate icon to use for the drawing package being created. I haven't been able to find one in the catalog browser so I'm wanting to see if anyone created one of these and would be willing to share or if there are any suggestions on an accurate way to build this block.
Replies (10)
Message 2 of 11
JReese-NC
I'm unclear if you are talking schematic or footprint. We don't use the 1734 line but with a brief look I would assume you are showing your 1734-IB8 in your schematic drawing and then adding the 1734-TOP on as a "Multiple BOM" item.
As far as the panel footprint it looks like the 1734-IB8 is included in ACADE but it is just the DI module itself. If this is something you use often I would probably build my own custom footprint of the 1734-IB8 combined with the 1734-TOP and just make that your standard footprint for this module.
If you don't already have the AB Product Drawings website bookmarked that is where you will find your AB drawings from and the 1734-TOP is available in both 2D and 3D.
https://www.rockwellautomation.com/global/support/drawings.page
JReese
Dell Precision 3450
Core i7-11700, 32GB RAM, NVIDIA T400
Windows 10 Professional
Autocad Electrical 2025
Message 3 of 11
I have the footprints of both the 1734-IB8 and the 1734-TOP. So when I show my subpanel layout I have them laid out for the build shop. I am referring to the schematic icon. I have the IB8 icon for wiring, but I was hoping to find the TOP icon so that I can show it as it will be built. It serves as a housing unit for the IB8.
I appreciate your response though. I  am considering that I might need to create a block for this but was hoping for a more accurate block than what I might end up making.
Message 4 of 11
jseefdrumr
You don't need to show the TOP by itself in the schematic; it gets combined into the overall symbol. For a good analogy, consider one of those 'ice-cube' relays that plugs into a DIN-rail mountable socket base. In that instance, you don't represent the socket and relay separately. This is because there is no actual wiring between the relay and the socket. It plugs directly into the socket and electrical connections are made that way.
Same thing for the  1734 terminal modules. They're just a base (like a socket) that accepts the I/O modules. All wiring goes to the terminal module, rather than to the I/O module. So, schematically, there is no way to actually represent them separately.
The 1734 stuff all exists in the parametric PLC database. See my attached images.
First is a detail drawing, but it's made from a layout drawing. It shows a 1734 Remote I/O rack. These footprints were assembled individually, meaning the 1734-TOPS is one footprint, the I/O modules are their own footprints, etc. (No subassemblies.)
Second shows a 1734-IB8S module in a schematic. (Safety Input module) Note that the terminal designations in the PLC symbol correlate to the terminals on the 1734-TOPS. The whole 1734 line is set up that way, because you can't use one of the 1734 I/O modules without a base, and all bases are numbered the same. (For instance, we use 1734-TOPS, which has spring terminals, and you use 1734-TOP, which uses screw terminals. But the wiring is the same, and the terminal numbers are reflected in the PLC.
Third shows a pair of 1734-IB8 modules. Note, the same terminal numbers. Also, note that there are other things like a CTM, FPD, etc.
These schematic blocks were all made with the parametric PLC tool, even the CTM and FPD. These are part of the normal ACADE install, so you should have them as well.
However, if you mean to construct a 'fixed' PLC block, my advice would be to do it the same way they do the parametric ones: integrate the terminal module into it.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 5 of 11
JReese-NC
I see what you are saying - since you are actually wiring the TOP and not the IB8. Really all user preference on what you want to show.
You could use the PLC Database Editor to modify the 1734-IB8 to your liking but what we do in scenarios like this with terminal bases is just use a description line to make it more clear. We focus more on what wires are going to what I/O points but the terminal numbers on the IB8 still represent the TOP base accurately.
JReese
Dell Precision 3450
Message 6 of 11
Thank you for sharing that. I had printed some user manual pages and was coming to a similar conclusion that the TOP was represented within the terminals. Your suggestion of changing the description line will definitely be an added bonus for the schematics and make it easier for the panel shops.
Message 7 of 11
Can you post a .DWG of your layout
Message 8 of 11
jseefdrumr
This isn't from the same drawing, and the footprints in it are a little different from what I was using when I originally responded to this thread. Back then, I had individual footprints for both the 1734-TOPS and the I/O modules that plug into it.
Now, I use a footprint that combines the TOPS with the I/O module in one graphic. This makes it easier to draw my layouts.
Also present in this drawing are another line of PLC, two different kinds of AB Powerflex VFDs, some contactors, filters, power supplies, the usual. It's almost all Allen-Bradley, and all footprints were made by me using their CADD files as a starting point. Feel free to use them in your own stuff.
Jim
Jim Seefeldt
Message 9 of 11
Cesar_velandiaVKVZS
Community Visitor
Community Visitor
diagramas autocad elecrical serie 1734 allen bradley
Gracias
Message 10 of 11
MMoeinifar
Community Visitor
Community Visitor
Hi Where can I find this drawing? Is there any library for 1734-IB8?
Message 11 of 11
arshdeepsingh404
Hello @MMoeinifar
The 1734 series is available in the Parametric PLC selection.
Use the command AEPLCP and browse to 1734-IB8
You can download the 1734 series footprints from Rockwell's website https://configurator.rockwellautomation.com/configurator/1734-TOP/summary
Arshdeep Singh
C.Tech, CMSE®
