Civil 3D Forum
Error 211
7 REPLIES 7
Message 1 of 8
2220 Views, 7 Replies
Error 211
Hi everyone. Im trying to run an SSA model, and everytime I do I get the message below. Any thoughts on how to solve the problem will be greatly appreciated! Thanks.
ERROR 211 : Invalid number * at line 10287 of [CURVE] section: Control-01 Control * *
7 REPLIES 7
Message 2 of 8
Could you attach a model?
Message 3 of 8
I tried to upload and it is not a valid extension (surprising). I can email the SSA file though if you dont mind. Thanks.
Message 4 of 8
Hello, No need to attach the model. Just check your control curves where you have defined a blank curve Control 01. Delete that curve and it will be done Thanks Amit Garg
Message 5 of 8
Thanks, that did the trick!
Message 6 of 8
The below worked for me for error 211:
Causes: Cross slope of the roadway in the model is too flat and the error should be a Warning indicating there is no solution for spread.
Solution: Increase roadway cross-slope or change basin to "on sag"
Tags (1)
Message 7 of 8
GREENLAMA7
Could you tell me where to find the control curve?
Message 8 of 8
pperales2
in reply to: GREENLAMA7
That is where the control setting is at.
Rail Community
