Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Exception thrown when trying to set targets for baseline region
2 REPLIES 2
286 Views, 2 Replies
Hi all,
I have got an exception "The SubassemblyTargetInfoCollection is not got from the BaselineRegion." while trying to set targets for a baseline region of a corridor. I searched online and found the following posts, however none of them is able to help.
Post I have found online:
https://forums.autodesk.com/t5/autocad-civil-3d-customization/corridor-target-assigning/td-p/4642747...
https://forums.autodesk.com/t5/autocad-civil-3d-customization/subassemblytargetinfo-targetids-error-...
https://forums.autodesk.com/t5/autocad-civil-3d-customization/set-targets-to-baseline-and-baselinere...
http://civilizeddevelopment.typepad.com/civilized-development/2013/05/subassembly-targets-having-fun...
My goal: to set a subassembly(LaneSuperelevationAOR)'s offset target to an alignment and elevation target to the alignment's profile
My code: THE EXCEPTION HAPPENS AT THE LAST LINE OF THE FOLLOWING CODE. THANK YOU IN ADVANCE FOR ANY HELP.
 // set subassembly targets
 SubassemblyTargetInfoCollection targets = centralCorridor.Baselines[0].BaselineRegions[0].GetTargets();
 foreach (SubassemblyTargetInfo target in targets)
       if(target.TargetType == SubassemblyLogicalNameType.Elevation)
       ObjectIdCollection ids = target.TargetIds;
       ids.Add(ProfileId);
       target.TargetIds = ids;
       else if(target.TargetType == SubassemblyLogicalNameType.Offset)
        ids.Add(AlignmentId);
       else if(target.TargetType == SubassemblyLogicalNameType.Surface)
             centralCorridor.Baselines[0].BaselineRegions[0].SetTargets(targets);
2 REPLIES 2
If anyone could provides a workaround, that's great too! Tons of thanks!
I tried to commented out the for loop and still have the same exception.
Rail Community
