Can anyone direct me on how to show additional/different information in the already configured reports in the report manager? i.e. the PVI & Curve report gives everything except the elevations of the PIs not associated with a curve. Why not just give all the PI elevations?? Therefore I have to print 2 reports see the whole profile. Seems like there should be a way to select/add/change the information that report kicks out. Please advise.
Solved by Jeff_M. Go to Solution.
Thank you for your feedback! Sorry it's taken me a while to get back to this. I've attached a pdf with the modifications I'd like to see made to the standard PVI Station & Curve report. Please let me know if you have any questions. Feel free to call or email me at the info. in my signature.
Green highlighted info. is necessary & needs to remain in the report.
Yellow highlighted info. necessary & duplicated.
Red lines are requested changes to be made.
It seems to me that these 2 reports could easily be combined into one for all users.
Concept of the changes is as follows:
Combine the data from PVI Stations & Curve report & the data from the PVI Stations report to make for one (1) holistic report.
Rename this report to "PVI & Curve report".
Add the elevation column & data from the PVI Stations report to the PVI Stations & curve report. Elevation data of all PIs (or just any PI not related to a vertical curve) generates in this new column.
Jessica, I've managed to make some edits to the PVICurve report. I believe this is what you were looking for:
The attached zip file must be unblocked in it's properties prior to extracting the new dll to a location of your choosing. Then edit the reporting tool to point to the new dll for the PVICurve Report, and be sure the Macro name is ProfilePVICurve. Note that I did this in C3D2016. If you need it for other versions I would need to create a new dll for each version of C3D.
That does look like what we need. Thank you! We are running 2017, so I would need to be able to plug this into it. I have one other request. Is there a way to put a file from which the data was printed? This information, again, is on the Station report & not on the Curve & station report.
I may need some hand holding when it comes time upload this.
Hi there. I've tried loading & running this, and I'm doing something wrong. If you have a few minutes in the near future would you mind helping me get this loaded?
That did it. I unblocked it after extraction. I walked through it again this morning & it worked. Thank you! I also discovered I wasn't saving it in the reports manager.
Would you be able to make similar adjustments to one of the horizontal geometry reports for us?
Good to hear!
Go ahead and post what you'd like modified and I, or anyone else who sees it, should be able to help you out.
I'm attaching markups for the horizontal geometry reports.
Also, if anyone has a report for superelevation, please share!
Any reason why I wouldn't be able to use the extracted .dll on another machine?
So the report you created is great. My engineer's love it! We are now running 2018 & 2019. Would you be able to make us a file for those versions? or let me know what I need to do to let it run in others? I tried running the 2017 in 2018 & got some weird error. I then looked back here to see we need a file for each version.
Awesome! Thank you. I can repost the 2017 report we are currently using, if that helps. Just let me know!
OK, I think this is now the same as the one I did before. This time I just edited the main C3DReport instead of making a special "Modified" reports file. ADter downloading, be sure to Unblock the zip file then you can extract it and replace the existing C3DReport.dll files in C:\ProgramData\Autodesk\C3D 2019\enu\Data\Reports\Net and C:\ProgramData\Autodesk\C3D 2018\enu\Data\Reports\Net Yes, I tested the same DLL in both 2018 & 2019.
Let me know if you see anything I may have missed.
Jeff
I'm not seeing the unblock check box.
