Window swing direction
Message 1 of 10
Is there a way to determine the swing direction of a window?
Jussi
Replies (9)
Message 2 of 10
Add a property set to the doorstyle with the automatic property Swing Direction.
You can then use it in tags and schedules.
Message 3 of 10
Yes, but what about windows?
Windows have swing directions, but they don't have automatic properties for
them.
I was wondering if there was some other way to determine it, through APIs?
Jussi
kirjoitti viestissä:5002439@discussion.autodesk.com...
Direction.
Message 4 of 10
You can get at it through the API, but it is easiest to just use a VBScript formula property set definition.
The definition will depend if you have 2006 and want xref ability.
For ADT2004 define a property set for windows with an automatic property of "Handle".
Then define a formula property named "Swing" and use the following for it's definition. Be sure to use the UI to pick "Handle" so that it appears in bold, cutting and pasting references to other properties does not work.
**** Start 2004 Script
On Error Resume Next
RESULT="--"
Set app = GetObject(,"AutoCAD.Application.16")
set window = app.ActiveDocument.HandleToObject([Handle])
set anchor = window.GetAnchor
if anchor.FlipX then
RESULT = "LEFT"
else
RESULT = "RIGHT"
end if
***** end 2004 script
For 2006 and Xref usage, define a property set for doors. Add the automatic property "ObjectID" and add a formula property called "Swing" with the following definition.
****** Start 2006 script
RESULT="--"
Set app = GetObject(,"AutoCAD.Application.16.2")
set window = app.ActiveDocument.HandleToObject([ObjectID])
RESULT = "LEFT"
else
RESULT = "RIGHT"
end if
****** end 2006 script
If you need me to post a drawing instead, just let me know.
Chris Arps
Message 5 of 10
Excellent!
Thanks!
Jussi
kirjoitti viestissä:5005567@discussion.autodesk.com...
"Handle".
RESULT="--"
RESULT = "LEFT"
else
RESULT = "RIGHT"
end if
RESULT="--"
RESULT = "LEFT"
else
RESULT = "RIGHT"
end if
Chris Arps
Message 6 of 10
I just noticed an error with the 2006 script, the correct line for using ObjectID/xrefs is
set window = app.ActiveDocument.ObjectIdToObject([ObjectID])
Chris Arps
Message 7 of 10
btw, make that
if anchor.FlipX Xor anchor.FlipY then
thanks again,
Jussi
kirjoitti viestissä:5008034@discussion.autodesk.com...
ObjectID/xrefs is
Chris Arps
Message 8 of 10
I can't get this to work. It only shows LEFT, and when i flip the window, nothing changes. Anyone know what's wrong?
This is what my code looks like:
RESULT="--"
if anchor.FlipY or anchor.FlipX then
RESULT = "V"
else
RESULT = "H"
end if
I use ADT 2006 if that is any help
Christopher
Message 9 of 10
Note Chris' correction in his Nov/09/05 reply:
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
Message 10 of 10
This does not seem to work either, I'm afraid.
Any other ideas?
Christopher
