Ok, I think I figured out what you are doing. Just prior to Step 1, you are selecting the Insert ribbon tab (either from the vanilla AutoCAD version or the AutoCAD Architecture version) and, on the Block panel, chosing the Insert tool. In the Block Gallery that deploys, you are then selecting A-Glaz (Step 1), to initiate the insertion of an instance of that Block Definition.
Then the X-scale factor of the block is set to 5 and the right-click context menu is used to use the Basepoint option, which allows a point other than the insertion point defined in the Block Definition to be used for placement. I still do not know what Steps 8 and 9 are, but if I skip those and try to place the block 7' from an acquired point, such as the corner of two walls, I get what I assume is similar to what you were getting. My solution is to make my own Steps 8 and 9. In Step 8, I click on the intersection of the corner from which the A-Glaz block is to be moved 7', placing it there. In Step 9, I select the A-Glaz block and select the grip at the insertion point. Then I move the cursor to the right and type 7' and press ENTER (Steps 10 & 11).
The attached Screencast illustrates the above. I did this in AutoCAD Architecture 2016, with the AutoCAD profile current (running AutoCAD Architecture "as AutoCAD"). The same can be done with an AutoCAD Architecture profile current; the Block panel is farther to the right on the AutoCAD Architecture Insert ribbon tab.
Screencast will be displayed here after you click Post.
5b7ef96e-0e00-4cd1-9a73-b794100ffa22
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
